Results 1 to 10 of 16
Thread: Nelson Performance 3- relay fan harness
    San Antonio, TX
    We have been meaning to post up our new dual electric fan harness.
    Our new fan harness functions just like the previous harness, however, we have improved the components.
    Key features that have been added or retained:
    TXL wiring. Resists high heat!
    OEM Crimped and soldered terminals.
    New Delphi Connectors.
    Heat resistant loom/covering.
    40amp rated waterproof/sealed relays.
    Locking relay connector/socket.
    Easy installation
    Detailed instructions.
    Operation:
    The harness is capable of operating just like the factory harness.
    The PCM is capable of triggering the fan relays based on engine coolant temperature and AC line pressure.
    Concern (reason why improvement was needed): A few vehicles that were equipped with our harness showed signs of terminal contamination. This was caused by the humid climate or washing the engine bay or other variables.
    As terminals become contaminated, they build up heat and cause more resistance due to arc build up. Eventually the relays became nonoperational.
    Fix: We now use only OEM type waterproof/sealed relays. These relays keep any moisture and contaminants off the terminals.
    New sealed relays. Notice the red seal is tight around the wire.
    Hi amp relay:
    In stock.
    Harness I'm running on the daily...easy installation
    Apr 2012
    LaVista Ne.
    Do you recommend replacing the old units?
    San Antonio, TX
    I wouldn't if ur not having any issues with it. The new one will function the same.
    We only changed to sealed relays due to some customers living in high humidity areas and for those who wash their engine bay often.
    A little dielectric grease on the terminals will go a long ways.
    Oct 2011
    San Antonio TX
    Cool may need some for a project we got going on.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Apr 2012
    LaVista Ne.
    Ok. Will do. Thanks for the heads up. By the way the updated tune you gave me a month is working fantastic. Once I fixed all the little things from the upgrade (self inflected wounds)... Thanks Allen Tell Erica Thank You also. She is great.
    Looks killer! Need a new project now!
