Results 1 to 3 of 3
Thread: TBSS/NNBS 2 Bar MAP Sensor.
    May 2007
    Oak Forest, Illinois
    Is there a 2 Bar MAP sensor that is a direct fit for the TBSS/NNBS intake manifold? I have No problem adapting another type to the intake---That is not the issue. Since I will need a 2 Bar sensor anyway, I may as well get one that is a direct fit if possible.
    Jeff
    98 GMC RCSB 2wd, 100% internally stock 305, w/twin T-3 junkyard turbos,Ramjet intake w/42lb inj,12200411 PCM. 4675lbs w/me in it. Best time in 5 passes 13.01@110
    Ponca City
    Part # 12615136
    Slowest in Oklahoma...
    May 2007
    Thank You!
