Got my lil brothers old truck and plan on swapping in a cheap 4.8 or 5.3 gen 4 with 799 or 243 heads and maybe to a home port and polish job, TH400 or 4L60 trans, 4.56 or 4.88 gears. 4000+ stall, cam that will pull up to 7000+rpm plan on shifting it around 8000RPM. I plan on upgrading rod bolts and rocker arms to help handle the rpm's along with the valve springs and lifter and pushrods. The truck will be gutted for light weight, cage will go in, simple wire harness no heat ac etc, flat black all over or possible rattle can camo job, factory steel wheels blacked out. Looking to do this cheap cheap cheap but reliable. Just want a fun truck to go play with this is a toy only. Any input on cam, gears etc is appreciated, traction devices preferred. I would like to lower the stance but keep a really soft ride, thinking about bagging the rear so i can soften the suspension how I want it and put a drop spindle on the front. Future plans would be to add a turbo so it would be nice to use parts that will compliment a turbo in the future, I know gears and cam will have to change but other than that it will be built with a turbo in its future probably a 76mm home made front mount....
