2002 Silverado HD for sale.
23300 miles
This truck is powered by GM's 8.1 liter (496) big block. It sends power through an Allison 5 speed automatic transmission and then on to a set of Yukon brand 4.56 gears.
Modifications include -
Performance -
Volant induction, ported throttlebody, Poweraid throttlebody spacer, The Other Guys mid-length headers, Corsa muffler/tips with custom dual tailpipes, Direct Hits Ignition. Comp Cam, Crane 8.1 ratio roller rockers, AS+M billet aluminum valve cover spacers and Westers'custom programming.
Suspension and appearance -
The front of the truck was raised with a 6.5" Full Throttle lift, GM's "green keys" and the torsion bars were cranked up to get a total front lift of about 8.5" The rear was lifted with a set of 4" Deaver springs and a 2.5" block. This helps clear a set of 37x13.5/17 ProComp Xterrain tires are wrapped around 17x8.5" Weld Evo Renegade XT wheels (these wheels only have about 300 miles on them). Other appearance mods include - Westin step bars, PIAA airdam with 40 series driving lights, clear corner lights, billet grills, tint, Stage I HID low beams and a polished driveshaft. The frame was also treated to a coat of POR-15 for a clean look and protection from the elements. The bed is protected by a spray in bed liner.
Interior -
Custom leather interior and Delphi XM satellite radio receiver.
The lift, gears, seats and tires have been on the truck since the Spring of 2004. They have about 4-5000 miles on them. There are about $12,000. worth of upgrades done to this truck. All of this can be yours for $25,500.
- You may not post replies
- You may not edit your posts
