Results 1 to 8 of 8
Thread: transmission question
    Jul 2009
    Oklahoma City
    Ok so im swapping a 5.3 into a 89 reg cab Chevy. Can I use the factory trans? And then just tune the ecm to not need the trans?
    Jan 2011
    Mcalester,okla.
    Yes trans will work. Then tune pcm for like the standord trans
    Jul 2009
    Oklahoma City
    Awesome. Do I need to use the 350 flywheel or the 5.3 flywheel. Cause I dont think the converter in the 89 trans mounts to the 5.3 flywheel. Maybe it does
    Austin, TX
    Quote Originally Posted by Venom View Post
    These are the parts you will need to adapt to an earlier transmission. Be aware you also have to egg shape the torque converter holes on the flywheel.
    GM 19260102 Engine Flywheel
    GM 12563532 Spacer to resuse stock trans 1
    GM 19257940 Flywheel bolts x 6
    And if you are bold I've heard of guys just putting washers in between the torque converter and flywheel instead to save money. I wouldn't suggest this method.
    Red 94 GMC Sonoma
    Red 94 Jeep Wrangler
    Red 02 RCSB Silverado
    Red 03 Ford Cobra
    Red 04 CC Silverado
    Red 05 Yamaha Raptor
    I really like red
    Jul 2009
    Oklahoma City
    Thank you very much.
    Jan 2012
    Thanks! i needed those too.
    Jul 2010
    Douglasville Ga
    Everything above is true. Also you will have to make a bracket to hold the detention cable. This cable must be hooked up to the throttle blade if you are going to use your 700r4.
    Jul 2009
    Oklahoma City
    Oh yeah forgot about that. Thanks.
