I have two new e-fan harnesses, these are for 03-04 trucks but would work on almost any ls engine based vehicle. Duel pin style. $80 each
The Fleet...
2003 Suburban- 5.4 L59 331CI 10:5.1 Compression -Built by ME
2004 Avalanche- 5.7 LS1 -NOT built by me
2005 Silverado RCSB- 5.7 LS6 -Built by ME
Pictures added, harness is extra long to allow mounting flexibility. Relays are activated by ground, either connect to pcm or a toggle switch. Ground green wire and both fans come on at low speed, ground both and both fans will run high speed.
The Fleet...
To the top
The Fleet...
What are the terminations? are these pinned to go into the ECU? And are they terminated for stock fans plug and play?
Harness is pinned for pcm, has connectors for 2005-2013 truck fans, plug and play for automatic operation if pcm is tuned for efans. Can switch connector to LS1 F body fans if needed.
The Fleet...
Thats a deal. PM me a paypal?
