Results 1 to 2 of 2
Thread: 4l80e question swap question for nnbs
    Sep 2010
    North East Ohio
    Does it matter the year? I found a good deal on Craigslist but the trans and transfer case is from a 95.. will I have problems putting in my 2010 or should I keep looking? I'm sure Ill need a different converter to make the spacing right since 95 would of been a Gen 1 block.
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
    Mar 2010
    San Antonio, Tx
    I put a 94 Core in my 02 2WD with no trouble but I have no idea about a transfer case, I would think the electronics are different. As far as converter, you could get a swap one or you will just need the 6.0 flexplate with spacer and longer bolts.
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
