Results 1 to 6 of 6
Thread: need a cai that kicks to driver side
    Jan 2012
    Ive seen pics of them on here just cant seem to find them tonight. Any help would be great
    Dec 2010
    The CAI in my GTO is driver's side.. Theres not really anything stopping you from fabbing your own.
    May 2011
    Buffalo, NY
    Take cai, rotate 180 degrees, now turns to driver side!
    Feb 2012
    What truck is this for older or newer? If newer then you should be able to just flip it.
    White Settlement, Texas
    Siliconeintakes.com should have everything you need to build it just the way you need it I've used them a couple times
    Jun 2009
    Caledonia, MI
    I tried doing the same but didn't work out because I still have my mechanical fan on the truck and it was hitting. If you have electric fans, it will work you can easy make some elbows off that siliconeintakes website work.
