Results 1 to 10 of 12
Thread: A/c wiring and temp gauge HELP!
    im running my stock compressor from the obs truck (89) model and my stock gauges, i have my harness from nelson but im totally lost on this part of the swap, tips please! thanks
    Aug 2011
    Galveston, Texas
    Quote Originally Posted by bowtieboy2692 View Post
    You run both of those accessories from the stock harness
    1992 Full size blazer 5.3 Swap successful.
    http://www.ls1truck.com/forums/lsx-t...zer-build.html
    Galveston, Texas
    So would i have to run the stock computer also?
    Dec 2010
    you would have to retain the factory AC activation circuit (which would come from the truck side, may or may not use the factory ECU in a way you need.. example bumping up idle) I'm no expert here as I'm deleting AC in my swap since its already non-functional anyway), the gauges run off of sensors that can be re-used from the factory engine without needing the ECU. You will need physical adapters in order to connect them to the block though.
    Sep 2011
    I'm in the process too and keeping my ac on my 94, I talked it over with Jon and he added a trigger wire on my new harness for when I activate ac so that my idle will not be affected,, I'm not sure yet where to wire this in yet as I have yet to get the harness in and look things over, I'm hoping he may include an instruction where to wire in the trigger wire
    Dec 2010
    I believe on a 99-02 ECU it will be pin 17 on the red connector, Dark Green with White tracer. No idea if it needs 12v+, 5v+, ground, or what. If I remember correctly this wire was connected originally to D3 on the C2 connector. Don't quote me on that though. The other possiblility is B5 on the C2 connector, this is a Lt Blu wire.
    Quote Originally Posted by 1991SSP View Post
    Jon from nelson? I guess i shouldve told him i was running my factory a/c /:can ha but i was thinking about just running the truck ecu as well. I heard another member talking about that. Thanks for the help man!
    Thanks for the help guys! Im tearing into somemore on thurs, had to take a break. A little frustrated ha
    Sep 2011
    Yes, jon from nelson is who I was referring to, try not to get frustrated, if you have the tools and take your time and with the help from a friend or two plus the info on this site it should not be too hard to get the swap completed
    Yeah i hear ya man, getting the main wiring done for the motor isnt too bad, its just the gauges im worried about, everything else is going pretty smoothly, i just want to make sure the temp gauge works so i dont trash the motor overheating it ha. Thanks for all help guys!
