Results 1 to 7 of 7
Thread: Remote tranny filter install
    Apr 2005
    Saint John, MO
    Okay, so i was gonna do my Transgo/trans work this weekend, but the new LPW pan didn't show up So instead of sitting around feeling sorry for myself, i decided to go ahead and install a Perma-Cool remote transmission filter. Not real exciting stuff, but it'll please Hit Man
    The kit included:
    - Remote filter mount
    - Perma-Cool filter
    - 2 3/8" x 1/4" NPT male elbow fittings
    - 1 3/8" x 1/4" NPT male straight fitting
    - 4' of pretty nice hose
    - 4 clamps
    - 3 sheet metal screws
    After surveying the situation, i decided mount it on outside of the frame (passenger side) right by the cross-member. I also decided to cut the supply line at the rubber hose (between the 2 steel lines) and splice in the filter.
    To do this i needed a couple of extra items:
    - Shorter filter
    - Mounting plate (made by me from 1/8' aluminum bar stock)
    - 1 3/8" x 1/4" NPT female straight fitting
    - 1 3/8" x 1/4" NPT male straight fitting (i didn't like the one that came w/ the kit)
    - 1 3/8" hose mender
    - 3 bolts/nuts/washers
    - 2 quick connect clamps
    This is one top view showing the filter mount and fittings. IN on the right and OUT on the left.
    Another top view showing better how the lines are run. I used the elbow from the kit and the female straight fitting to make a mender for the return line from the filter. You can see that better in the next pic.
    A good view of the splices. The return line from the filter (on the right) is coming "towards" you and then "up" to the radiator cooler.
    A couple of shots from underneath. It was getting dark outside, so these aren't that great, but you get the idea.
    Base: 2004 Victory Red Silverado 1500 2WD RCLB, LR4, 4L60E, 3.73, HD Suspension, P245/75R16 Tires
    Mechanical/Performance: Nelson 93 Octane Tune (See Slamma's CarDomain.Com Page for more details)
    Apr 2005
    So it will use a regular oil filter?
    03 SIlverado LS SCLB 4.8 w/ 3.42 rear, K&N FIPK, mild catbak duals, vette servo and a few other things added.
    http://img.photobucket.com/albums/v2...hughes/600.jpg
    Apr 2005
    Saint John, MO
    Hey kirkrhughes, how's it going! Someone finally asked me a question about this really captivating mod My feelings were starting to get hurt
    Anyhow, it uses a 'Ford Type' filter w/ 3/4-16 threads. The install sheet had a little matrix of compatible filters for both normal and "tight" fit. Wix was one of the choices. The kit came w/ a Perma-Cool filter, but it looked kind of "STPish" and i use CarQuest (equals Wix), so cool. I went w/ a shorter CarQuest so it would "tuck" into its mounting location better.
    Apr 2005
    I've been thinking about doing the oil filter relocation and maybe a cooler too, now I can add the trans filter to the list too.
    Apr 2005
    Saint John, MO
    Cool. Like i said, the remote trans filter deal isn't all that sexy, but it's sure gonna help clean the fluid much much better than the pan filter, and it added fluid to the overall capacity.
    Yeah, i really like the idea of the remote oil filter setup. The AMSOIL Bypass kit looks like the best of the bunch, but not cheap. Which one are you looking at?
    Apr 2005
    Was looking at the Perma-Cool on JCWhitney $44.99 for the single. If I do get one I will probably mount it with the filter upside down, already have to put 6 quarts of oil in the thing.
    Apr 2003
    Mansfield, Texas, USA
    Ah, here this is at. An actual filter on the trans, more capacity by around a quart, and pics!
    That mounting area is about where I was thinking too.
