Harness connectors
Looking for the following connectors from a 99-02 (or compatible.. not sure) engine harness. I was told the harness I bought was uncut.. apparently this was not the case.
MAF sensor
Crank Angle Sensor
1 Injector harness (prefer with pigtail to splice please)
Park/neutral safety
I can use an IAT breakout and a MAP relocate harness if I have to, and I think I could bypass the safety switch, obviously injector connectors can be found anywhere, so the primary worry is the crank angle sensor connector.
Thanks.
- You may not post replies
- You may not edit your posts
