Vats deleted, but now P1626 code???
I have an 04' Colorado which I put a 5.7 LS1 out of a 2000 Camaro in it, I bought HPtuners a couple weeks ago so I could disable VATS out of both computers. I did so without too many problems, now the truck starts up perfectly but dies seconds later. I scanned the Colorado body control module, and it has a U1000 code (serial data 2 loss of communications). The dealer told me to take the hot and ground off the battery and touch them together to reset this code, I did this and it worked.
The problem is when I scanned my LS1 computer, It is showing a recent code of P1626 Theft Deterent Fuel Enable Signal). Is there anyway of bypassing this, other than grounding out the TDM (theft deterrant module)??
Any help at all would be awesome!!
*When I turn the key on the fuel pump does prime, just runs out of gas in about 3 seconds.
- You may not post replies
- You may not edit your posts
