I have an 04' Colorado in which I am doing an LS1 swap currently, the stock power steering lines are no where near the right fit for the new setup. I saw that RUSSELL has power steering lines braided that hold up to 2500 psi, and they also have a bunch of fittings for power steering setups. My question is my rack and pinion setup does not have threaded fittings, they are smooth metal lines that go into the rack and pinion and are held in place with a single bolt between the two lines. Can I tap these to have metric threads, and then I can buy the appropriate fittings and braided hose ?? Has anyone ever done this??
