Results 1 to 10 of 18
Thread: 5'' Aluminum Driveshaft
    was on my 2008 silverado reg cab with 1350 yokes and trans was a 6l90e
    $450
    heres a pic when new next to a oem
    heas seen speed of 155 with no issues/vibrations etc
    San Antonio, TX
    Keep in mind if your truck requires a shorter drivershaft, this would be an excellent shaft for rework!!
    Just to add, it's not the cheap thin aluminum, this is good quality aluminum and billet yokes.
    Damn thing was over $600 new.
    This would be a perfect shaft for an 80e setup, regcab. As you can see the new shaft is longer, which can be cut down to accept the 80e stuff.
    funny how the 6L90e is shorter, hmmm.
    this is a big dog shaft no b.s
    Sep 2011
    Might help the sale if you posted the center joint to center joint measurement. Glws
    Ponca City
    How does this compare to a 99-07 classic rcsb 2wd shaft? Length wise?
    Slowest in Oklahoma...
    center of u joint to other center end is 60'' inches.
    Arizona/Utah
    Would this even be close on a ecsb 2000 with an 80e swap?
    Don't think so
    Dec 2011
    How long is it
    U joint mount to u joint mount is 60 inches 400 and it's yours
