Results 1 to 3 of 3
Thread: Scout 4wd
    San Antonio, TX
    Scout 4wd
    Doing a conversion on a scout. Well the drivetrain part. Using a 5.3L, 60e, and the question is the tcase. Wanted to use the electronic case but I need a passenger side tcase. Is there such a thing?
    The front assembly requires the shaft on the passenger side.
    Thx.
    Jan 2012
    Go with atlas. Not electric,but bad arse. Fully clockable
    Jan 2011
    Mcalester,okla.
    Just Use a early 80 -87 chevy 208. Its clocked correctly and splined for the 700r4 which is the same bolt pattern and splines as the 60e. Dirrect bolt up.
