Results 1 to 6 of 6
Thread: Summit racing window switch
    Is anybody using one? If so what are your thoughts on it?
    ok... so what is everybody using? lol
    Sep 2010
    North East Ohio
    What is the part number of the window switch you are looking at?
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
    I use a button
    Sep 2010
    North East Ohio
    If you are thinking of using http://www.summitracing.com/parts/SUM-830452-1/ You will need a Tach adapter since your engine is DIS. The msd version will work without an adapter http://www.summitracing.com/parts/MSD-8969/
    Cam, Stall, 4.88's
    Oct 2006
    Wichita Falls Tx.
    You want to wait a couple of days. I have another shipment coming in for our controller. Window switch, with progressive up grade. It costs a little more but does alot more.
    Online Store
    [/CENTER]
