Results 1 to 4 of 4
Thread: Using 4wd
    Jan 2012
    Corpus Christi, TX
    Using 4wd
    I notice when I'm in 4hi and I step on the gas the truck has no go!!! Does this have to do with the torque management?? I'm still new to all this. I plan on getting Nelson tune in couple of weeks hopefully to solve this problem if that's the reason. Any help would be appreciated. Thanks, Eric
    Arizona/Utah
    You have significant parasitic loss when running in 4wd. You need to remember that when you run in 2wd you only need to turn 2 tires vs 4.
    Quote Originally Posted by 5.3L11z71 View Post
    Its a combination of parasitic loss and traction control.
    I easily lose half a second in the 1/4 when in 4x4.
    Jan 2012
    Corpus Christi, TX
    Appreciate the help fellas.
