Since I had a v6 in the truck previously, I was planning on using all the accessories from my LS6 with my truck conversion. However, I've discovered that on the '02 truck (harness I'm using) the compressor has a high pressure switch built in the compressor (the rear connector). The ac compressor on the LS6 doesn't have a high pressure switch. Any ideas what to do here? Can I ignore the high pressure connector on the '02 harness?
I thought about just installing a truck ac comp and bracket, but wouldn't you know it.... the pulleys do not line up and best I can tell, this method would require swapping everything to a truck accessory setup.
