Results 1 to 4 of 4
Thread: fuel pressure
    Apr 2005
    i have the 99 ls1 and when i check fuel pressure its aroung 85-90 psi itss flooding the engine making it run poorly.I talked to th guys at S&P and he told me if i was installing the ls1 in a 96 or newer and i had the older 99 ls1 that i could run my stock setup.i have a supply and return on my engine but i am getting nothing on the return side.ANY suggestions THANKSSSSSS Timmy
    May 2004
    How is your fuel supply and return set up? Are you running an aftermarket regulator or the 97-98 vette fuel rails with return line?
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Apr 2005
    i am running a completly stock setup.I have the original fuel pump from the 96 vortec truck, original filter, and its connected to the 99 ls1 stock fuel rail .I was told by S&P that this setup was fine but its not working for me any ideas ???
    May 2004
    If you're running the stock 99 fuel rail, there's just a dampner in the rail. You need to get a 97-98 vette fuel regulator to replace it with. How did you make the return line work?
    97 GMC, 2002 LS6.
