I have a couple of swap questions. I am changing to an 87 gas tank with the baffles and going to run a Walbro in tank pump. My 87 sending unit has 3 lines 1/4", 5/16" and a 3/8" I was planning on using 3/8" for the feed, 5/16" for the return. Also I did away with the charcoal canister. Do I need to vent the tank ? If so, how would be the best way to do that ?....My 5.3 has a 2 wire plug connected to the alternator, a brown and a gray wire. My 84 has a 2 wire plug for the alternator, which has a red and a brown wire. The truck has gauges. Which wires do I need to connect to the 5.3 from the 84 plug, and where do they need to go ? Will my volt gauge read correctly ?
