hp tuner vs pro
So looking through their site, and the tuning section here and pt but can't find the exact answer. I understand that the difference with pro is the box that can do data logging and run wb input and the ability to do sd. If I don't plan on doing sd and only running NA for the next year year or two (can upgrade later) what are the other benefits of pro? As always, thanks fellas!
- You may not post replies
- You may not edit your posts
