Results 1 to 10 of 11
Thread: Gear shop in S.A.?
    Aug 2004
    Magnolia, TX
    Gear shop in S.A.?
    Anyone have someone they trust? I had Thrash do the gears in my 06. Looking for 4.56 or 4.88. Wanting to get the gears done before the tune. TIA!
    Quote Originally Posted by 2k5Squirrel View Post
    NP can do them. They have done a lot of gears.
    Mar 2010
    San Antonio, Tx
    Just do it yourself! Only special thing you need is a dial indicator and inch pound torque wrench for pinion load.
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
    Dec 2008
    san antonio TX
    Can Nelson Performance do gear installs? i wanted to get it done a while back but they recommended me to someone else. If they now do it, know some people that need it done can send them their way. wish they would have done mine, because there the only shop i trust my truck with.
    No No No Nelson can not do gear swaps,right now he has a Turbo setup to get done!
    Oct 2011
    San Antonio TX
    Quote Originally Posted by CHEVROLADE View Post
    Unfortunately he did tell me he wouldnt be able to install mine any time soon
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    May 2012
    Floresville
    I can set them up, I've done several for a few
    Of NP customers. Give me a call 210-842-5425
    Quote Originally Posted by Got Torque Diffs View Post
    where are you located ?
    Oct 2011
    San Antonio TX
    I called a while back n np said they stopped doing gear installs. What gives.
    Nov 2009
    SAN ANTONE
    Quote Originally Posted by rs/ss 4.8 View Post
    i called a while back n np said they stopped doing gear installs. What gives.
    just too busy with lots of big builds no time to stop just to do gears
