Results 1 to 7 of 7
Thread: How are you guys getting to the brake light switch on the OBS for the TCC Ground?
    Sep 2011
    I'm trying to finish up the wiring and I need to hook up the TCC Ground wire. It's the one that has 12v at all times then 0 volts when you hit the brakes. How are you guys getting to the brake switch? I can barely even see the thing? Is there somewhere else you're hooking into? My truck is a 95 w/t.
    http://i160.photobucket.com/albums/t192/abrrymnvette/2004z06.jpg
    Nov 2011
    Arlington, Tx
    It needs 12 volts ignition power at all times, until the brake is pressed. Then it needs to cut power while the pedal is pressed down. Just get a test light down there on the brake switch and start pressing the pedal
    PERFORMANCE-TUNING-FABRICATION
    12617 FM 917
    Alvarado, TX 76009
    Sep 2011
    Quote Originally Posted by LS3CC View Post
    I can't even get my hands to the switch. It's on top of the brake pedal arm. My hands are too big.
    Nov 2011
    Arlington, Tx
    Lol, I take small hands for granted I guess. You can drop the column down quite a bit by taking off the two nuts that hold it up. Then you should be able to get to it
    12617 FM 917
    Alvarado, TX 76009
    Aug 2010
    If the wiring is the same as on my 92 c1500 there should be a brake signal wire that goes to the old ecm. It's a purple wire that runs to the C207 connector that splices into the engine harness behind the glove box.
    Aug 2024
    Thoughtful planning helps ensure spot and linear track heads work together without visual conflict. Spot heads deliver concentrated beams that highlight specific decor, while linear heads distribute light smoothly across larger zones. The right combination creates layers that feel unified instead of scattered. Mid-ceiling placement of Pendant Lights can complement the arrangement, adding a vertical element that blends well with horizontal track lines. Adjust each head to avoid harsh overlaps and maintain a smooth gradient of brightness. With careful spacing and angle control, both head types cooperate to create a dynamic, adaptable lighting experience.
    Aug 2025
    Hey, neulich habe ich beim Surfen zufällig ein Online-Casino gefunden und war zuerst skeptisch, weil ich bei anderen Spielen vorher kleine Verluste hatte. Dann entschied ich mich, play jonny auszuprobieren und startete mit dem Spiel „Lucky Wheels“. Nach ein paar unglücklichen Runden hatte ich plötzlich einen großen Gewinn, was richtig aufregend war. Besonders spannend fand ich die speziellen Boni für Spieler aus Deutschland. Seitdem spiele ich öfter, weil es Spaß macht und eine gute Möglichkeit ist, nach einem langen Tag abzuschalten.
