Results 1 to 10 of 17
Thread: Need help connecting fuel lines
    Sep 2011
    I have a 95 with the two fuel lines. Supply and return. I'm using the truck ls intake, so I have a return line on my fuel rail. I can't seem to find anything to connect to the factory fuel lines on my truck? I have the pieces to go from the push-loc to barb on the intake fuel rail. But can't find anything to screw into the truck's fuel lines. Do I need to cut them and then flare them?
    Cut them and use a compression fitting.
    May 2010
    Galveston, Tx
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by silverado_lover View Post
    there he goes lol!
    May 2010
    Galveston, Tx
    Mannnnnnn that was like 22 days ago
    Sep 2011
    Atlanta Ga
    lol i just seen it...im still having problems with this thing and these fuel lines. i used a tube cutter and cut the lines what i dont understand it how you connect the steel braided hose to the connectors is there something im missing
    Quote Originally Posted by abrrymnvette View Post
    Your trucks fuel lines have the male end of the GM oring flair; cut that off and use your flairing tool to make the ISO bubble end. Then use some fuel high pressure fuel injection hose to complete the connection.
    Another way would be to get a set of fuel lines from a truck that matches your intake, cut as needed and connect with compression fittings or flair the ends and use a threaded union..
    Easy peasy right ?
    swap : 88 k5 Blazer w/ 2004 5.3 & 4l60e, 212/218 cam
    CAI, shortie headers, TCI 2600 stall, transgo shift kit,
    Nelson tuned
    Sep 2011
    Thanks guys! I was trying to avoid compression fittings just for the look. Thanks for the diagram silverado_lover! That answers any possible questions.
    http://i160.photobucket.com/albums/t192/abrrymnvette/2004z06.jpg
    phoenix az
    old pic of my fuel lines. no compression fittings
    1998 chevy 1500 with 6.0/4l80e comp cam, tune, exhaust,
    Sep 2011
    That pic is too small, can you post a larger version
