Results 1 to 8 of 8
Thread: STS, LS6 cam, 8psi
    Dec 2003
    Newark, Tx.
    We just finished the install on a '05 Yukon, 5.3. We installed an LS6 cam and springs, front mount intercooler, Gt-67 STS, and 8psi.
    http://www.trtturbo.com/images/tx_ve...hange_dyno.jpg
    http://www.trtturbo.com/images/Texas_Vehic...xchange_004.jpg
    http://www.trtturbo.com/images/Texas_Vehic...xchange_005.jpg
    http://www.trtturbo.com/images/Texas_Vehic...xchange_003.jpg
    I'd say 438/446 was pretty good, especially with 24" wheels.
    San Marcos Texas
    Nice job! What are the IAT's with the intercooler? I hope to get mine IC before long and run a bit more boost!
    Dec 2003
    Looks good 438/446
    2000 Chevy Silverado 2500 ECLB w/6.0 , 4L80E auto, 4.10 G80, K&N, Nelson Dyno Tune, 02 PCM STS TURBO , 44# injectors, IC ,HPTuner and 160* thermo 348 rwhp, 394 rwtq @ 5 psi
    60'=2.241
    1/8=9.352@77.39
    1/4=14.40@ 96.67
    Jun 2004
    george west texas
    damn...those are some nice numbers...way to go billy
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Dec 2003
    Newark, Tx.
    The front mount we used we had custom made with rear facing openings. It made for a very clean install. There was a dramatic difference in the temps from one tank to the other. So far the intercoolers are working great!!
    Sep 2004
    I'd love to see more pictures of the intercooler install if you have them. What are the dimensions of the intercooler?
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    May 2005
    Those are sweet #'s for 8psi! Is the LS6 cam ideal for a forced induction truck?
    ●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
    Dec 2003
    Newark, Tx.
    To me, the LS6 cam is a good option because of the grind and the $$$.
    You can find take out LS6 cam, springs, and push rods for less than the cam alone in most cases. Its all according to what you want. If you want a little lope, then you need more than the LS6 as it is on a 118.5lsa.
    We are starting a new car soon, a '02 Trans Am, and it will have a Lingenfelter GT-7 cam;
    208/230 .554.546 121 with #317 casting 6.0 head front mount intercooler, 42lb inj, STS turbo with some custom work done. I am thinking the numbers will be even more impressive. Looking for around 500rwhp at 7psi we hope.
