Results 1 to 10 of 10
Thread: help with DTC P1345
    Dec 2008
    san antonio TX
    help with DTC P1345
    have a stock 1998 tahoe 5.7L with 200K miles , it has a DTC of P1345. the truck starts fine, it has a little miss, and has a stong raw gas odor (seems to not be burning the fuel right). has anyone had this problem? where should i start to fix it?
    San Antonio, TX
    First step would be to identify the code.
    It's a crankshaft to camshaft correlation error.
    Sep 2010
    McPherson KS
    Check your distributor, those caps are notorious for cracking and allowing water in. Your cam sensor is run off the distributor rotor, and once it gets a little damp it causes all kinds of problems. That's where I would start looking at least, easy to get to and check.
    Dec 2008
    san antonio TX
    i read up on it gonna start with a new cap & rotor. then try to get a scanner on it to check the timing. can a loose worn timing chain cause this DTC?
    Jun 2010
    baxley,ga
    yes a wore out timing chain can cause it.pull your cap off and turn the motor over by hand to check your slack.ever time i've ever seen that code,the motor was out of time
    04 rcsb forged 347
    Dec 2008
    san antonio TX
    ok cool thanks will check it tomorrow.
    Sep 2010
    McPherson KS
    At 200k, that chain is probably due for replacement anyway.
    Feb 2010
    Central Texas
    distruber gear are common wear item, eventally will strip out. Pull dist cap ck backlash on rotor if it has a lot than gear is wore out and needs replacement. If it feels good than get scan tool on it and set timing, clear code and problem should be solved.
    Quote Originally Posted by 96/chevy/pu View Post
    +100000000
    This is the proper answer from someone I ASSume does or has been paid to work on these. We call it "apple-cored". The HVS drive gear is most likely toast. What happens next is it breaks off a tooth and won't run.
    I replaced the gear on my 4.3 after about a billion and a half revolutions to prevent the tow bill. Looks pretty good (still have it) but obviously very worn after well over 200,000 miles.
    Feb 2010
    Central Texas
    Yep seen a few, but now work for the state, to much up and down pay and benefits next to nothing. Pays not great but steady and benefits far better, until state goes broke and we all get canned, hope it doesn't go that far.
