Results 1 to 7 of 7
Thread: nv3500 guys!
    Sep 2009
    Peoria Az
    nv3500 guys!
    just curious what you guys mean by swapping to quality fluid, as in clutch fluid or trans fluid, and what kind do you use to make it shift better or perform better.
    Any advise is welcome thanks in advance
    4.8\5 speed\3.23's\Airaid TBS\Flowmaster 40 Series Muffler\Volant Power Core CAI w/ Scoop\0/2 Drop\
    Mine has RP SynchroMax in it. If you want it to shift nicer pick up a Centerforce clutch. As far as clutch fluid, just flush it fairly regular. I believe it uses dot 4. Can't remember.
    Sep 2009
    Peoria Az
    haha may have to change the clutch fluid. i put dot 3 in it at about 33k miles. did you notice any difference with the rp fluid?
    Couldn't tell you. I did a whole bunch of stuff all at once, built 5.3 replaced the 4.3, new fluid in the trans and hydraulics, new clutch.
    Pittsburgh, PA
    Do the drill mod or replace the clutch line. This alone will make a huge improvement.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Sep 2010
    Mcdonough, GA
    I have a centerforce in my truck and it feels great. Just curious Quick. what is the drill mod?
    1992 rcsb. Stock lq4, 85mm mass, e fan, lts true duals, magnaflow, t56, tru trac, 4.10s, slap bars
    Pittsburgh, PA
    its easier to google it then esplain. they show pics of whaty ou need to drill and etc
    Quote Originally Posted by johnmichael397 View Post
    412 Motorsports
