Results 1 to 3 of 3
Thread: Got a new part to fix the wiring harness issue!!!!
    Nov 2011
    Stuart, FL
    It's going to be fun!
    Its the Edelbrock Performer RPM Manifold
    I am going to rebuild the carb and paint it, it's a Holley 750cfm
    I will be keeping my stock 4L60E so I will modify the TPS sensor to the Carb.
    Oct 2011
    San Antonio TX
    Always wanted to see an ls with carb. Go for it
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Nov 2011
    Stuart, FL
    It is going to be a fun build, I have been debating between EFI or Carb for awhile. I already had this carb lying around, and just found this intake on craigslist for $225 new in box so I couldn't pass it up. I'll order the MSD Box to control the Coils and I will be buying the 5.3 in the next few weeks, I will be posting pics of the build. I like the ability of tuning the carb myself when I swap a cam or other go fast parts instead of sending out the ECU.
