I finally got my 93 gmc lm7/4l60e swap drivable but I'm having an issue with my trans. I rebuilt it before I installed in into the truck so everything's fine mechanically inside with maybe the exception if a stuck vlv. My trans shifts nice and firm for the 1-2 and 2-3 shifts but will not shift into 4th gear the the convertor licks up fine right at 45-50 mph but not 3-4 shift. If I pull the shifter into the 3rd gear spot then the convertor disengages and wont lickup again. Any ideas what maybe the cause of this other than maybe 4th gear vlv being stuck? Also what effects would increasing my line press in my pcm tune have on the shifting? Would it just shift firmer or will it move the shift points as well? Any ideas or help is greatly appreciated...
