Results 1 to 9 of 9
Thread: Working on a Cobalt..got some Q's
    ok so the car its my cousins....05 cobalt 2.2ecotec.....she lost control and fell in a low water crossing....
    brought it home....it turned on just fine but had a broken oil pan,radiator and e fan...
    i replace
    oil pan
    radiator
    filled radiator
    put new oil and filter
    turned it on but it started kinda like a smeely steam coming from the reservoir as i was filling it up
    it wasnt knocking or anything...the idle had a slight miss...so t
    so i turned off and go to start it and its rough as hell...barely wants to crank over
    i checked the dipstick and it did not mark anything like wtf
    so i go under and i drained the oil and it came out with water
    im thinking as i filled the radiator that water was going to the pan
    i removed plugs and they were covered in water
    my cousin mentioned it was steaming smoking etc etc
    what yall think? head gasket? i think im just gonna replace the motor
    Sep 2010
    McPherson KS
    Sounds like a head gasket to me.
    i just tried cranking it and it blows the water out of the reservoir
    Arizona/Utah
    If it overheated could have warped the head or block even. I tore a Saturn apart in high school that was overheating and this was the case. Could be something else.
    Mar 2011
    Amarillo TX
    I would definitely say it sounds like it is some manner of the heads not sealing to the block (head gasket/warped mounting surface)
    just my two cents
    2000 ECSB 5.3L with K&N CAI, true duals with flowmaster 40s, and 200k miles!
    Nov 2009
    SAN ANTONE
    replace the engine
    Jun 2011
    Dallas/Plano, Texas
    Put in a 5.3
    Derrick ; truck stolen
    going to get another engine ..thanks
    Apr 2010
    Trussville, AL
    go 2.0 lnf turbo
    its just a turbo 5.3 that a couple of kids threw together
    01 silverado
    09 cobalt ss
