DSCN2486 [640x480].JPGDSCN2488 [640x480].JPG$8000 OBO lower price...I have owned the truck since new, clean and clear title in hand, never wrecked.
5.3 v8, comp 224/230, 588, 114 lsa cam, new style comp 918 springs, comp hardened pushrods, rocker arms off of a 07 5.3, LS2 injectors, Pacesetter ceramic long tube headers, ORY pipe, NGK Iridium plugs, MSD plug wires, Electric fans from FLex-a-lite, Larger than stock trans cooler, KN air intake with AEM dry flow filter, ARP crank bolt, Fully Built 4L60E from Wiley transmission in Round Rock same guys who built DB Rods trans, Yank TT 3000 stall with ARP converter bolts, CAT racing SFI Flex plate with ARP bolts, custom steel drive shaft from Inland Truck parts from here in Austin, upgraded spicer u-joints and straps, fully rebuilt rear end with all new bearing and seals, 3.73 gears, Detroit True-Trac posi, Bear rotors up front with Hawk Fero carbon pads, new stock rotors and pads out back, Russel stainless brake lines front and rear, Hotchkis sway bars front and rear, Hotchkis 2 inch drop coils up front with Beltech 4 inch drop in rear via front spring buckets and shackles along with shock extenders, Edelbrocks IAS shocks front and rear, Recently rebuilt entire front suspension April of this year, HUBS, BALL JOINTS, TIE RODS ALONG WITH GOOD ALIGNMENT, Nissan wheels painted flat black with clear coat on top, Pirelli P-zero Rosso 255-55-18's in front less than 2k miles yokohama Advan st 285-50-18's in rear, shaved tail gate is painted flat black at the moment, sir michaels roll pan as well, 10% window tint on front 5% on rear window, interrior is clean non smoker no burns, factors cd player, dash light swapped to green led's, auto meter fuel pressure gague, stock chrome grill has been sanded n painted black, new head light housing and marker lights. cant think of anything else, shoot me a pm if your interested. few things i missed.. has trans go hd-2 shift kit, walbro 255lph fuel pump, and catch can hooked up to the right valve cover, New Bosch oxygen sensors as well, and new speedo sensor in trans.
