I was wondering if anyone knew if the 4.3s use the same transmisson bolt pattern as the 4.8,5.3,and 6.0s. Are they all the same besides the internals and would it work with the V8's?
Have you had any problems with the durability of it.
They are the same pending year
Slowest in Oklahoma...
2000*GMC longtubes nelson tune, built trans,trutrac circle d 278 mm stall 373 posi,100 shot of dope and 228 232 588 595 cam.
It will most likely not have any of the band-aids GM put in the trans for V8 trucks. I'd rather start with a V8 core unless I was doing an all-out most all part inside replaced build.
