Results 1 to 3 of 3
Thread: Transmission Line Help
    Mar 2010
    Lone Star State
    Hey guys I don't post a whole lot, just read and research mostly, but I have a question I cant find the answer to. I have an 04 Chevy Z71, 5.3l 4l60e, this weekend I did an 05+ efan installation, with a 34" radiator out of an 09 (I think) State Trooper issue Tahoe. It had radiator cooler on pass side like my original 28" rad, and also had oil cooler on the driver side. The transmission cooler connections in the 34" radiator had a slightly smaller thread than the original 28", but when I put the male sides in and popped the clips on, I gave both the top and bottom one a few tugs and neither would come off.
    Today I had the tune done to activate the electric fans through the pin connections in the computer. I took it around the block, made it about half way around and lost tranny pressure and power. Immediately pulled over, popped the hood, and the lower tranny line had come out of the quick connect in the radiator and spewed fluid everywhere. I reconnected it, pulled on it harder this time, and again it still didn't come off. It seems very secure. Did I just not get it secure the first time? Or are they slightly different? I cant find any definite answers anywhere. I'd like to have one before I go refill it with tranny fluid and try it again.
    New transmission line connection
    Old one removed from 28" radiator
    San Antonio, TX
    The fittings are the same for both radiators. Probably just didn't push in the line far enough for the clip to seat behind the flare.
    Just keep an eye on it. I'm sure it'll be ok now.
    IIRC there the same, id be looking into an external cooler if i was you, i just dont trust using the enternal one as i had one bust and kill a FLT transmission
    Simple: 408 on steroids!
    single digits coming soon!
