Results 1 to 5 of 5
Thread: 1996 RCSB S10 LSX swap
    Oct 2008
    Scott, Arkansas
    I've got another option on the table right now so I would need the scrill to go that direction. I'm only posting here because it's an LSX swap already in progress (just needs putting together and finishing). I don't really want to seperate because a lot of the parts are specific to S10 swaps. Details are as follows.
    1996 RCSB S-10 (was 4.3/5speed truck)
    '99 LS1 block/crank/pistons/rods less than 12k miles on the rebuild
    LS7 lifters
    LS6 heads and intake
    Vinci 216/224 .551/.551 cam
    Built 4L60e with deep trans pan
    TCI SSF stall
    Sanderson 1 5/8 coated headers
    CPW poly engine mounts
    I already have the motor and trans installed and the fuel system plumbed (Vette filter regulator, returnless). I also have the Fbody plastic tank mounted at the tail of the frame like the blazer tank setup (fits prefectly). It has a Racetronix fuel pump. Dual intrepid fans and Jegs radiator. Kwik performance alt/PS relocation bracket and vette type II pump (NIB not intalled). Aluminum remote PS reservoir. The frame is notched and boxed for the AC. I also have a Ford 8.8 and Fbody front and rear brakes plus Z28 5 spoke wheels and brand new tires to go on it.
    I'm asking $4500 and that's barely what I have in this WITHOUT the cost of the LS1/4L60 since I already had that. All that is needed to complete the install is a CPW harness, hooking up the shifter (saved the camaro shifter). installing the radiator, fans, hooking up the PS and AC system, getting a driveshaft and installing the 8.8.
    2005 Silverado SS AWD
    AEM CAI, ARH LTs, HD-2 shift kit with vette servo, Circle D 278mm 3200 stall Madtunesracing.com street tune (MTR now has a Dynojet 248 chassis dyno)
    13.82 @ 94.92 w/1.83 60'
    Pics of the truck please! Sounds like a KILLER deal
    Oct 2008
    Scott, Arkansas
    http://www.s10forum.com/forum/f213/l...s-10-a-462500/
    This is my build thread...it is a deal for sure.
    Oct 2008
    Scott, Arkansas
    I've decided to move the motor and trans back to an Fbody instead. I have $2488 in parts plus the complete truck. I'm asking $2000 for everything listed here.
    1996 RCSB s10 (clear title)
    H3 oil pan kit
    1 5/8 Sanderson shorties
    CPW poly motor mounts
    Jegs universal radiator (28"x16.5")
    Kwik performance alt/ps relocation bracket
    Vette remote ps pump
    KRC ps reservoir
    4 5 spoke Z28 wheels with 4 brand new 235/60/16 Falken tires
    2" aluminum wheel spacers for the front
    new side mirrors
    dual intrepid electric fans (these are the monster dual speed fans)
    Ford 8.8 with axles and a non locking diff and 3.27 gears
    Oct 2008
    Scott, Arkansas
