Results 1 to 5 of 5
Thread: Oil Filter Selection
    Jan 2007
    Stafford, VA
    NOTE: This is not a question about what BRAND to purchase, so please, I'm not going there.
    I bought an A/C filter the other day to do an oil change. I noticed when I pulled the old one, it was a PF46 (I believe). The new one was a PF61E. It was bit longer, but otherwise appeared the same width and screwed right onto the oil filter boss. Started the engine with no leakage issues, so I'm thinking this is golden. I'm just wondering if anyone knows which one is the correct filter, or does it even matter? I like the idea of the longer filter for any vehicle. Brings back memories of using the BBC filter on the SBC because it held more oil and had more filtering capacity. Any thoughts?
    - Paul J.
    2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
    2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
    (SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
    (SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
    (SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
    (SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
    San Marcos Texas
    The f bodies use a shorter filter that is the same as the trucks but doesn't stick down below the pan. I've used both and can see no difference.
    Mar 2010
    Paris, TX
    The A/C book list the PF46 as the replacement. But if it seals up fine I would use use it. Going to check this out when I go back work Monday. Thanks for the tip.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Paris, Texas
    46's for trucks and some f bodies
    61's for lots of chevy, buick, pontiac, and olds cars
    i've used either of them for the last 6 years
    Jul 2005
    modesto, ca
    I found out about the PF61 filter about 5 years ago and when I asked the parts guys a the dealer they told me it was a severe duty filter, so I started using them.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
