Results 1 to 5 of 5
Thread: Couple questions on a 95 4.3 to a 4.8 ls swap
    Sep 2011
    I've got a 95 4x4 work truck with a blown 4.3. I also have a complete 4.8 out of a 2000. I'm going to swap in the 4.8 but still gathering info. Here are the questions I can't seem to find answers to:
    Can I use my 4.8 harness to splice into the gauges and run them? I just need to find the "tach" wire on the 00 harness and connect it to the "tach" wire on the gauges? Same for water and oil?
    Can I use the 2000 A/C compressor as long as I get the lines mated to the 95 lines?
    I don't need to do anything to the wiring on my trans? It's an automatic.
    The swaps seem pretty straight forward so far. I have access to AllData at the shop so I can print out diagrams until there are no more trees.
    May 2007
    Medford, OR
    Quote Originally Posted by abrrymnvette View Post
    Seems to me that a little more research needs to be done.
    http://www.ls1truck.com/forums/lsx-t...onversion.html
    Youre welcome.
    Rockwall, TX
    i know on my 5.7 tbi to 5.3 i had to re-use the oil pressure sensor and water temp sensor, i had to get some adapters from street and performance just call them up they will know what you will need.
    As for the a/c the new compressor will not fit without cutting a good notch out of the passenger frame rail, there are a few options you can do.
    novak a/c mount is what im going with and then there is josh powers a/c bracket and you can search around and find out more but they will allow you to retain ur factory a/c compreesor,lines,and wiring
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Building the truck GM never did..
    Rockwall, TX
    Quote Originally Posted by ccreddell View Post
    Youre welcome.
    +1
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Sep 2011
    Quote Originally Posted by T-Stark View Post
    Thanks! That helps a lot!
