Originally Posted by
1978steven
A leveling kit on an OBS is a waste of money, the stock torsion keys will allow you to crank the front suspension more than enough. The problem you are going to run into is that the wheel offset, especially on a 20x10, will not allow you to run that 33x12.5. Now on stock wheels or wheels similar to stock specs you can probably fit them 33's. Do your research on torsion bar cranking, the more you crank the less suspension your gonna get outta it, and then there's the harsh angles it's gonna put on everything from the steering to the ball joints and even cv's.
What he said. Get a 20" wheel with close to stock offset and crank if you're not wanting a lift. Run either 295/55 or 305/55 Trail Grapplers.
2012 Honda Civic Si - DD
