Results 1 to 9 of 9
Thread: Lowing kit for 2011 GMC Sierra ,,, need help
    Jul 2011
    Hello all
    a friend has 2011 GMC Sierra regular cab Z71, who is looking forward to drop his truck
    i've googled about that and nothing make sense at all !!!
    Therefore i'm looking for your help and suggestions guys.
    I will be pleased if there are pictures because we don't know how does 3/4 look like or other size.
    regards
    Jun 2009
    Washington DC
    look up all the popular manufacturers like Ground Force, McGaugheys, DJM, etc....
    Orono, ME
    Okay, first off, a 3/4 drop on an NNBS RCSB is going to have a TON of rake to it. I would suggest going 3/5 at least. To that note, I would do all McGaughy's drop parts as they are the company that most people have the best success with. McGaughy's part number 34025 should give you the best parts to complete your friends drop. Up front, you'll have spindles and coil relocators to give you a 3" drop, out back will be a flip kit with 1" lift hangers to give you a 5" drop. That way, if you get done and it still has rake, just take the lift hangers off to get a full 6" rear drop. You'll also need some drop shocks for the rear, Belltech Street Performance shocks are the way to go. The drop kit is ~$700 and the shocks should be ~$120.
    Answers to other questions that may come up: No, you don't need to notch at 5" or even 6" of rear drop on an NNBS and No, you don't need helper bags or air shocks on a 5" or 6" rear drop.
    2012 Honda Civic Si - DD
    I did 4/7 on my buddy's 2011 it was quite easy to say the least... def listen to bart bout the McG drop they are way ahead of others in satifation territory imo!! Wont be rough like the other less expensive drops.
    Feb 2011
    Barnwell, SC
    On my 08, I did the springs, drop shakles and removed the blocks. With a load, it would ride on the bump stops the whole time. I was considering helper bags, then I sold it.
    Good luck getting the 4x4 any lower than 2" in the front. And good luck with ball joints.
    Orono, ME
    There are a multitude of people on GMFS that have NNBS 4x4s that are 4/7 and even 5/8 and are have no issues utilizing 4 wheel drive.
    Edit:
    Here's a ECSB 4wd at 4/7 IIRC with 24x10s and 285/30 Nittos
    And here's a CCSB 4wd at 4/6 with 24x10s and 295/35 Nittos
    And lastly, to the OP... here's an RCSB 2wd at 3/5... you can see how even at 3/5, the RCSB's have rake.
    None of that was available when I was looking a year ago for the 08
    Arizona/Utah
    All those trucks look dang good!
