Results 1 to 7 of 7
Thread: Turbo drain
    The Garage
    Turbo drain
    Just wanna make sure my drain is sufficient here. When I clocked my turbo, the center section ended up at a very small angle instead of pointing straight down. I can't set it up any other way cuz of the location. Will the oil still drain out of the turbo sufficiently?
    Oct 2006
    Wichita Falls Tx.
    Looking at your drain fitting. Anywere from 5:00-7:00 is fine. Even a little harder angle it will still work.
    Aug 2009
    Fort Riley, KS
    Got any pics of new setup...
    04' RCSB, LQ9, Front mount T76, TU1, Circle D 3K, Built 4L60E, True Trac, 3.42:1, 4-6 Drop
    Aug 2009
    venice, florida
    yea! pics or no anserws!
    5.3 2wd upgrades: Nelson tune, stainless lt's, magnaflow, e-fans, msd's, cai.
    The Garage
    Sorry, no pics. Just wanted to be sure my drain will work.
    Mar 2006
    Mesquite
    This probably falls in line with the "5:00 - 7:00" answer, but I've been told they shouldn't be clocked any more than ten to twelve degrees.
    San Antonio, TX
    based on having a couple of rearmount setups, it'll still drain if the fitting is sideways, mine did, for thousands of mile.
    that scavenging pump helps a lot with drainage.
