Results 1 to 10 of 20
Thread: What next?
    San Marcos Texas
    I don't post up too much what I've been doing, it is not a secret, just haven't said much. I have a STS kit sitting on Allen's floor and will be going next Saturday. In addition I have 42lbs injectors (thanks Jerry) a new driveshaft (aluminum 4" w/high performance u joints) and a driveshaft loop. I ordered the GT67 with a bigger housing. When I first did the LS1 swap I would have never considered a turbo, but with STS I've seen the light. I'm loosing the cats and figure I'll have to get used to it being loud. With tuning I'm hoping to be over 400WHp and in the 12's with stock boost (I guess we'll see how much abuse a mildly modifyed 4L60E will take). We will dyno it right before and after the install. Hopefully some track time will post up some new numbers. My truck has always responded well to mods and I'm hoping this will be more of the same. This is a custom install of a STS kit and I'm sure can be made to fit other combos. Don't hold back, just say what you think LOL!
    Jun 2003
    cool man i hope it all works.
    as far as mine. after the verter swap with allen my truck will be all back to stock. and then it will be sold or traded in.
    04 supercrew 5.4 3 valve-magnaflow catback
    formerly 02denali 12.79@107
    San Marcos Texas
    Man I always liked your truck(even though it was a bitch at times). I thought about buying a Denali many times! I hope you find the vehicle you will love as much, but I'm sure you will alway miss/think about your truck. Someone will get a hella deal on buying it whatever thay pay for it. What is next?
    Apr 2005
    Is the STS the one that mounts under the truck? If so, how hard woud it be to do a twin turbo set up that way?
    03 SIlverado LS SCLB 4.8 w/ 3.42 rear, K&N FIPK, mild catbak duals, vette servo and a few other things added.
    http://img.photobucket.com/albums/v2...hughes/600.jpg
    San Marcos Texas
    Yes it mounts under the truck. I'm sure twin turbo could be done, but the lag might be real bad, depending on the size of the turbo ect. Most twin turbos i.e. Supera's are two independednt turbos, one comes on at low RPM's the other at high RPM's. I think most setups use one turbo even in raceing apps.
    Dec 2003
    Newark, Tx.
    What about a stall. To me that is one of the best mods you can do with the STS.
    You could loose a little gear if the chance came up.
    San Marcos Texas
    That might be a good idea. I had a stall before and had zero traction even with my slicks, so I'm sure it will get worse with the turbo. I might even go with a good bit less gear like maybe low 3's.
    Jan 2005
    Humble/Houston TX
    jellous of the sts. i was thinking about sending the tb for a cheap porting and a nelson tune as soon as the planets align and allen and my scheduels match up
    then i have GOT to pay this thing off
    old mod list: H/C/I/N/E/G 408
    Jun 2004
    george west texas
    congrats...your gonna love it im shure
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Apr 2005
    The next mod in my future hopefully will be a job, have an interview Monday morn.
