2007 L59 5.3/4L65E into 1948 Chev pickup
I have installed a 2007 L59 5.3 and 4L65E transmission in my 1948 Chevy pickup. I used 2001 Camaro cast iron center dump exhaust manifolds to clear the frame rails. The Camaro exhaust manifolds has the O2 sensor in the manifolds above the outlet for the exhaust dump.
Would this be a better location for the O2 sensors or should I weld in a bung and place the O2 sensors in the exhaust pipe about 12 to 15 inches from the manifold?
- You may not post replies
- You may not edit your posts
