Results 1 to 10 of 22
Thread: Converting 86 k10 to an 04 silverado
    Jun 2011
    Sioux Lookout, Ontario
    Quote Originally Posted by kevin500 View Post
    Greetings from Thunder Bay!
    I am using a tank from an '87 and an ACDELCO EP381 pump . The pump fits right in the sending unit, and the tank is baffled for a pump. I prefer in-tank pumps, they last for years because they are not out in the elements. Quieter, fewer connections.
    On my '83 C-10, I would have had to notch the frame for the passenger manifold to clear, and the stock y-pipe would have interfered with the front drive shaft, even with a good sized lift. Unless you went with duals or modified the y-pipe....
    Thanks. One of my tanks is already a tbi tank with matching sending unit and pump. I guess its just a matter of switching the pumps, correct? I would like to keep two tanks, since it gives me added range. I've read of a pollack switching valve that holds up to 60 psi or so. What do/did you use for the valve? Regulator?
    Figured the exhaust wouldn't fit, can't have anything to easy... Probably purchase a manifold back system for the truck, and just make it fit.
    Sep 2011
    Don't blame you for wanting 2 tanks. You have a bit of a drive if you want to travel anywhere.
    Yup, the pump is just a swap, fits in the stock TBI sending unit. Saves a little hassle. I just have to run new steel fuel lines, I don't trust the aluminum ones that are in there now. They worked good for a carburetor, but I don't trust them for injection.
    I am using the Hooker headers for a square body, but they will not work with a 4X4.
    Jun 2011
    Thanks. Everything here is 4 hours away as you know, so range and reliability is key. I have the fuel line from the silverado that I robbed parts from. Its a little long, but it has the right connectors on either end. Hoping to use it to plug into the vette regulator, and just use a combo of rubber and steel hose to connect to the tank through the switching valve. Think it should work.
    Which motor mounts did you use? I'm looking at dirty dingo, but they are quite pricey. Probably going with an advance adapters flywheel/clutch combo for the trans end.
    Thunder Bay and Sioux Lookout. You guys make me feel like I'm in the sunny south. For the Texans, these guys are farther away from me than I am from you. And they're in the same province.
    Sep 2011
    Um, you ARE in the sunny south. 6 inches of snow yesterday here.
    Sep 2011
    Quote Originally Posted by dothedew View Post
    Dirty Dingo mounts were ones I was considering. But I went the overly expensive route, bought the kit from SPS that has the motor mounts, tranny mount, and crossmember. I could/should have went the other way, but I am motivationally challenged at times, and did not want to order from various suppliers. I wanted to make sure that everything lined up and that I did not need to play with the driveshaft length. That is REALLY pricey around here. I am not far from bolting it in, so I will know if it works. Also bought the headers from them. Yup, being lazy has it's price.
    Jun 2011
    Its done
    Don't feel like repeating what I already wrote once. See thread on LS1tech @
    http://ls1tech.com/forums/conversion...silverado.html
    Post any questions here, and I'll answer them as they come.
    Jan 2012
    Post
    That is a lot of information. I have a 1994 GMC Sierra SLE 2500 3/4 ton 4X4 pickup. This is a little newer than yours but feel as if there are some similarities, i.e. clearance issues with the exhaust and the transfer case.
    I am contemplating the same switch, an LS1 for my 350 TBI. I am looking to improve the fuel economy and the reliability of my daily driver. I am really new to this idea as I just happened to park next to a truck today that was about the same year as mine and got to talking with him about the LS1 swap. There seems to be a tremendous amount of information on the web and not sure where I should start. I hear there are many companies that offer simple conversion kits, i.e. engine mounts, wiring harness, fuel issues, exhaust issues, and don't forget the ever important electronics.
    So the information that I have gathered so far is that this is relatively simple given the fact that none of this is to be taken lightly, this is a major swap.
    The area that concerns me most is the electrical. The match up of the speedometer, the transmission wiring, the o2 sensors, the fuel gauge, the water temp gauge, etc..... Is this all dealt with in the conversion wiring kit made for the swap? How much else do you have to change to make all this compatible with the older technology? Are the dash gauges so different that there needs to be some major changes.
    Sorry for the bad organization of this post but as I said I am new to this idea. Until now I was just considering on another 350 TBI model. But have been concerned because I am wanting the better fuel mileage and the better technology of the newer engines. And don't want to shell out a lot of money for a newer truck. My current truck is somewhat sound except for the 190K on the odometer.
    Thanks for any help to start the ball rolling.
    Jun 2011
    I did the TBI swap about this time last year. It wasn't bad, but it left a lot to be desired. Compared to the LS, we'll, there is none. The LS is a whole other engine in itself. There is a lot of info out there, so its sort of hard to disect exactly whats what, I get that. Best advice I can give is to take lots of time to research and make a list. Find someone else who has done somethings similar. You mentioned somebody you met who did it; I'd get their phone number and have them over for beer. They'll likely feed you all the info you need first hand in 15 minutes, vs 7 days of internet searching.
    Electrical is a bit a of speciality. Those harness I sent out come back as a standalone harness. It allows the engine to run with 3 wires, and thats it. It requires LS engine sensors (Like MAF, O2's, cam sensor, etc) that are/should be part of the engine to run it properly. However gauge info you're on you're own. The LS computers do have some outputs, like an electric speed output, tach signal, etc. You'd have to research, but I believe there isn't much to make you're stock gauge work with the LS stuff. For mine, I had to wire in a resistor for my aftermarket tach to work. My speedo is cable driven, so that didn't change. Still having issues finding a temp sensor that fits. Sort of its own little problems. But if the engine runs, other stuff is just details.
