Thanks. Everything here is 4 hours away as you know, so range and reliability is key. I have the fuel line from the silverado that I robbed parts from. Its a little long, but it has the right connectors on either end. Hoping to use it to plug into the vette regulator, and just use a combo of rubber and steel hose to connect to the tank through the switching valve. Think it should work.
Which motor mounts did you use? I'm looking at dirty dingo, but they are quite pricey. Probably going with an advance adapters flywheel/clutch combo for the trans end.
- You may not post replies
- You may not edit your posts
