Removed LT1 and elected to go LS Based in my swap vehicle.
If you do not see a part and it comes on an LT1, I probably have it so just ask. I have most parts.
Prices do not include shipping and are negotiable. Shipped from 29483 or Local pick-up. Call or EMAIL. Serious inquiries only Call 843-327-9821
LT1 CNC Ported Cylinder Heads - $850
CNC ported flowing 270 cfm @ .600" Lift
Three angle performance valve job
54cc combustion chambers
Manley Stainless Steel 2.00"/1.56" valves
Comp Cam springs, Ti-17 Locks & Retainers
ARP 7/16" Rocker Arm studs - $50
ARP 7/16" Pro Series Rocker Studs (ARP 234-7202)
Guideplates - $25
Black Oxided Steel Guideplates (Comp Cams 4820-8)
Trickflow ChromeMoly Hardened Pushrods - $75
For Use with Guideplates : Yes
Tubing Diameter (in): 0.313 in.
Pushrod Material: ChromeMoly
Top Tip Style: Ball
Bottom Tip Style: Ball
Intake Overall Length (in): 7.200 in.
Exhaust Overall Length (in): 7.200 in.
One-Piece Pushrod: Yes
Oiling: Yes
Tapered: No
Tip Attachment: Formed
Top Tip Diameter: 5/16 in.
Bottom Tip Diameter: 5/16 in.
Wall Thickness (in): 0.080 in.
Heat-Treated: Yes
Quantity: 16.
Comp Cams 1305 Pro-Magnum Rocker Arm 1.6 Ratio - $175
Rocker Arm Mounting Style - (Stud),
Rocker Arm Ratio - (1.6)
Rocker Arm Style - (Full roller)
Stud Size - (7/16 in.)
Rocker Arm Material - (Chromemoly steel)
Self-Aligning - (No) requires guide plates above
Rocker Arm Body Style - (Standard)
Rocker Arm Nut Style - (Polylock)
Slot Width (in) - (0.562 in.)
Maximum Spring Diameter (in) - (1.500 in.)
Rocker Arm Finish - (Natural)
LT1 Ported Intake - $200
Ported for 58mm TB or mono blade. runners have been ported and gasket matched
Powdercoated red.
Summit 58mm Throttle Body Part Number: SUM-227703 - $175
Throttle Body, Twin 58mm, Aluminum, Satin
Comp Cams "Extreme" LT1 Camshaft 236/242 ($245 New) - $175
236/242, .520/.540 112 LSA, Very aggressive street/strip cam.
Stroker engines, Heads, Headers, High Stall or M6, Gears,
Computer Tuning Required.
LT1 Block Off Plates - $15
1 EGR Plate, 1 Intake Plate, Made from 6061-T6 Billet Aluminum.
Thank You for looking! Need to move these to continue the rest of the turbo swapThe number is for my dad as those are his parts.
