Results 1 to 10 of 26
Thread: waited a long time
    waited a long time
    First off glad to be here i have waited a LONG long time to post here and its finnaly here. i have a 96 obs swbexc truck and i am finnaly swapping out my tired 305. i just bought an 6.0 and 4l80E out of a 05 3/4 ton with all the accesories. i bought the schoenfields the BRP adapters i am ready the question is when i called nelson today i said i want to drive by cable not wire. She said i should get the custom harness and PCM from them. which i said i would but then she said my speedo wont work. my question is whats not going to work what else am i going to have to splice? i really just want to plug and play maybe have the 2 harnesses mated is there such a service thanks for the help.
    Also which TB do i need to buy for the 6.0 to drive by cable?
    Thanks in advance
    Eddie
    Dec 2004
    San Antonio, TX Area
    Welcome to the site. I did a swap on a 1990 RCSB so mine was different. We have quite a few swaps done here. Maybe someone that did a 96 will chime in. Can you still get the pedal and module from the truck to keep your DBW? That would be the easier way to do the swap.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Hey bud welcome, are you sure its a 6.0, not insulting your intelligance but my buddy bought a 6.0 bolted to a 4l80e out of an 05 3/4 tons, turns out that 6.0 is a 5.3 some of the long bed 05 3/4 tons are 5.3s
    All you gotta do is feed the 05's speedo output into your truck harness speedo input...the GM (I should say our trucks) speedos for the most part use the standard 4k feed, even back into my year range (91) and probably a little earlier.
    I swapped an 0411 into my 98 tahoe using Lextech's spreadsheet and my speedo works fine, which tells me that it is plug and play. Should be the same for you, also. My 0411 directly feeds my 91's cluster, no issues.
    the pinout for your 96 is here
    http://www.lt1swap.com/1996_vortec_5.7/index.htm
    the pinout for your 2005 is here
    http://www.lt1swap.com/2004vortec_pcm.htm
    that lt1swap site is awesome, btw.
    The owner of the junkyard said its a 6.0 and the vin did as well is there another way? i will look into the site for the pin out thank you
    with that being said do i need a custom harness or do i just use the one that came with the 6.0?
    and will the ac work or do i need to re-wire that?
    Rockwall, TX
    could look on the block behind the ps pump and Alternator bracket and it should say 6.0 and if its a 5.3 it will say 5.3/4.8
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Building the truck GM never did..
    May 2010
    I've got a brand new nelson harness for sale and it's setup for cable driven nt electronic tb.with PCM.I ended buying a 2000 gmc so no need for the harness I bought or schoenfields.pm me if interested,I'll give u a great deal.also the cable from the pedal on ur 96 is long enough to be used on ur 6.0 intake tb.
    took the pump off she is a 6.0 awesome!
    2008 G8 Gt
    2010 Camaro SS
    96 Chevy Pickup LS swap
    Rockwall, TX
    Congrats man!
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    done i will post pics later, runs great its bogging down under intial acceleration though.
    2008 G8 Gt
    2010 Camaro SS
