Results 1 to 8 of 8
Thread: Cam kit
    Nov 2009
    Spring, TX
    Smile Cam kit
    I've been looking around for a good 800 to 4000+ rpm cam... found some but havent been able to find any kits. I want a cam kit with like the valve springs, maybe lifters... If anyone knows a good site i can get one from please let me know.
    Pittsburgh, PA
    look into thunder racing they sell kits for around 700
    as for your power band, LS motors dont start coming alive till higher rpms. Hell how many other motors do you know peak torque at 4200 stock? old SBC peaked torque much lower
    and if you have a 4.8 youll need a higher rpm range just to keep up with larger cubes
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    San Antonio, TX
    We have some kits, they start at $710 for the single springs, pushrod, cam, or $745 for the lunati dual spring kit, pushrods, cam.
    all aftermarket cams are going to pull to 6000rpms, even the stock ones pull up to 5700rpms or so.
    probably the best cam we've used for lowend torque is the 208/212, which will still pull to 6200rpms.
    Little more aggressive would be 212/218.
    Neither will need an aftermarket converter for a daily driver.
    Nov 2009
    Spring, TX
    Thank you nelson, im guessing if i get a cam from you it would be easier for you to tune as well.... Im going to try that 100 extra hp to the wheels post you did... all i need is the cam and LT's.... do you think i will be pushing a little more if i have more done then the test truck?
    San Antonio, TX
    Ya, every mod does help with power in some way, so if you have a little more than the test truck did, I don't see why your truck wouldn't lay down more.
    Nov 2009
    Spring, TX
    Would you happen to know the stock rwhp on a 2005 4.8, mine came with the double electric fans as well.... Im guessing mine started with a little less power than the test truck you used but i dont think its too much less.
    Nov 2009
    Spring, TX
    The only other mods I have that you didnt list is CAI, Eaton posi with 4.10s, vette servo, Glasspack, and upgraded wires.
