Results 1 to 10 of 10
Thread: Kenne Bell 2.8h supercharger kit COMPLEAT, 8 rib, Killer Chiller, headers
    Apr 2005
    The Woodlands, TX
    I'm going back turbo and selling my blowers setup. I'm selling EVERYTHING that is needed to instail this. All the little stuff I had to buy to put it on my truck.
    Its a Kenne Bell 2.8h big bore intercooled supercharger. Approx 25k miles. No know issues, just got back from a 3k mile road trip in 5 days had no issues with any part of it. Here's what you get...
    2.8h liter (1 bar, high boost design case) Compressor
    Heat exchanger and all hoses, pump, Killer Chiller (uses trucks AC to cool the intercooler water to lower IAT's)
    8 rib drive setup with IW 8" over drive crank pulley, 8 rib PS, Alt, and Magnuson HD tensioner.
    8 rib 3.25", 3.65" pulley's and 3.75" 4" 6 rib pulleys (the 3.65" pulley makes 15psi on my 5.7 LS1)
    All the fuel lines and fuel regulator for return fuel system with connections to just plug right into stock fuel lines.
    60lbs/hr injectors and fuel rails.
    Edelbrock 90mm throttle body and 4" air tube and filter for it.
    Pace Setter headers.
    There is probable some little stuff I am for getting about but you'll get everything I take off the truck.
    I'm selling this as a COMPLETE kit and not wanting to part anything out unless someone just wants to buy the blower and then I'll sell the other stuff.
    $4995.95 for the COMPLETE Kit
    $3995.95 for just the blower and 6 rib drive
    Also has provisions for meth both below the blower at the discharge and into the mouth of the blower
    Also replaced the IAT with one that protrudes out into the tub
    Let me know if you have any questions or any offers. Thanks!
    01 ECSB 1/2 ton 4x4 6L GMC
    11.03@127
    KB Racing Borg Warner S475 turbocharged
    http://i3.photobucket.com/albums/y57/Kbracing96/kbracing96copy-1.jpg
    This just made me wet!
    OMG..
    well, i know you wanna change.. ill just pray to the speed gods you have this when im ready to buy something.. i love that damned thing!!!!!
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    Sallisaw OK
    i would love to buy the 8 rib setup from you if you decide you want to seperate anything. what size is the SC pulley?
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Apr 2005
    The Woodlands, TX
    Quote Originally Posted by 567234ta View Post
    It's still on the truck and not selling anything or coming off till someone buys at least the blower. The 8 rib setup will most likely go with the blower. Can't imagine someone not wanting it. I've got 3.25" and 3.65" 8 rib pulleys and 3.75" and 4" 6 rib pulleys.
    11.03@127
    Apr 2005
    The Woodlands, TX
    Lower PRICE! $4995.95
    11.03@127
    Quote Originally Posted by kbracing96 View Post
    yer killin me here!
    Sallisaw OK
    Yeah i need the pulleys, i have the same setup im using a 3.25" also but it's only 6 rib.
    6.6L 4l80e
    MY GARAGE
    Apr 2005
    The Woodlands, TX
    Offers??
    11.03@127
