Results 1 to 2 of 2
Thread: Hurst Pro-Matic 2 Ratchet Shifter
    Aug 2010
    Cannon Falls Mn.
    Hurst Pro-Matic 2 Ratchet Shifter PN# 3838500
    This is new and was only used for mock up purposes on my 408 SBC S10 . It is just sitting in the garage so must go.
    NOW LISTED ON EBAY http://cgi.ebay.com/ebaymotors/ws/eB...m=120705339259
    I will still make a deal here and end the listing early...
    $100 plus shipping
    http://www.hurst-shifters.com/hurst-...CHET-SHIFTER_5
    The Hurst Pro-Matic 2 Ratchet Action Shifter is quality engineered for years of precise, trouble-free operation. The Pro-Matic 2 gives a custom appearance to any vehicle and is ideal for street or strip performance. The Pro-Matic 2 for trucks incorporates an extended shifter stick for ease of operation and is designed to fit most pick-up trucks. Full forward and reverse ratchet action can be used with either standard or reverse pattern valve bodies
    OPERATION OF SHIFTER FROM PARK: From the park position, lift up on handle and pull back into reverse. From reverse pull back into neutral, push down and ratchet into gear.
    OPERATION OF SHIFTER FROM DRIVE GEAR: Ratchet into neutral. Pull up on handle and push into reverse. From reverse, pull up on handle and push into park.
    • Cable-operated to provide your choice of mounting locations
    • Progressively illuminated gear position indicator
    • Incorporates a neutral safety and back-up light switch assembly
    • Attractive black textured console with chrome-plated top cover can be trimmed to fit any floor contour
    • Chrome-plated stick and a black knob (3/8-16 thread) give the shifter a custom look
    • Complete with hardware, heavy-duty 5' long shifter cable, and easy to follow installation guide
    • Positive reverse Loc/Out for NHRA and IHRA requirements
    99 4x4 5.3 NELSON TUNED / 02 Ls1 CAM / 02 Ls1 "241 Heads" Port/Polish milled .045" / 03 INJECTORS / AIR RAID JR. INTAKE / PORTED THROTTLE BODY / TR55's / EGR DELETE / E FAN's / CAT DELETE / EXHAUST DUMPED
    Headers, Transgo HD2, 3200 stall, 4.56 gears coming soon.....
    Aug 2010
    Cannon Falls Mn.
