Results 1 to 5 of 5
Thread: dyno'd 6.0 in 01 blazer
    Mar 2011
    Summerville, SC
    Went to the dyno yesterday to get the blazer dyno tuned after I picked it up front the exhaust shop. Swap was completed the day before.
    MOTOR IS 2006 lq4 with 317 heads
    Mods are
    227/227 .614 115 lsa lsl cam. Setup for turbo in the future
    Upgraded springs
    Trunion upgrade also
    4" ricer intake tube.
    Sanderson shortie headers
    Magnaflow x pipe
    Magnaflow muffler
    3200 vigilante stall converter in 4l60e
    26" tall drag radials
    1st pull was 315 hp and after tuning it went to 360 RWHP.
    100 shot went up to 420hp. I will have to get the dyno sheets to show all numbers. I tried the 200 shot but the cam IMO , isnt set up for nitrous and it was just wasting it.
    All tuning done at HHP CAROLINA with hptuners
    Jul 2009
    Cool, that shows what a difference a tune can make.
    2002 Under Construction Again!
    Birmingham, AL
    60hp from a 100 shot?????
    01 Silverado
    Jan 2007
    Stafford, VA
    Quote Originally Posted by sprayedenali View Post
    If it's set up for a later turbo install, it's going to have less compression. N20 and lower compression won't play as well as a higher compression motor (at least this is my theory and I'm sticking to it )
    - Paul J.
    2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
    2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
    (SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
    (SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
    (SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
    (SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
    Mar 2011
    Summerville, SC
    4 degrees of timing was pulled. I am running br8 plugs gapped to .035.
    I also used stock jetting for the nitrous outlet plate.
    Sorry, I haven't posted the graph yet. I am at the s-10 supernationals racing. We are data logging it and trying to get it down the track. Running into 120+ degree IATS right now and trying to get it to stop pulling timing. Running 7.70's with this setup. I am also trying to get the suspension and tires dialed in. I went to spray it last night at the track with the 150 shot and I only picked up .1 with it. I believe I am having either a solenoid issue or a switch issue. I will get it figured out today though.
