NNBS Intake, TBSS TB, Xlink, Pro. Fuel Rails
Intake has about 600 miles on it. Perfect condition except I ground away a little bit of material beside the fuel rail bolt hole so I could use aftermarket rails with it. You cant see it when fuel rails are on it. $140 shipped
Also have a 4bolt TBSS LS2 throttle body, which is the same as the newer truck ones...I think. $60 shipped.
Professional Products fuel rails 10614, I have everything and the box. About 600 miles on them, worked fine. $120 shipped.
Xlink for the tb with about 8k miles on it, works fine. $180 shipped
Ill do the intake + throttle body + xlink for $350 shipped
intake + tb for $180 shipped
everything for $440 shipped
- You may not post replies
- You may not edit your posts
